Generator questions >
Generator questions
Generator questions
Old 03-31-2008 | 02:11 PM
Default Generator questions
My boat has a Factory installed onan 6.5KW gennie. I have a question. Lets say I am anchored out on the lake. Will the generator running keep the batteries charged when running a stereo system with amps? I know its designed to run the a/c unit, etc.
The boat has a built in charger, but I believe it charges the batteries at 10amps, which Im sure the stereo system draws more than that. New to the whole generator thing. Thanks
MILD THUNDER is offline
Old 03-31-2008 | 02:39 PM
I don't see why not. Just because it is only charging at 10 amps doesn't mean the batteries can't keep up. I suppose if you tried to run it maxxed for several hours you could have an problem.
Running the AC is a whole different animal, that is the same as being on 120V shore power.
PJDiesel is offline
Stormrider
07-18-2007 03:42 PM
Pwrbt33
01-23-2007 09:16 PM
LOTO Silverton
05-03-2005 05:06 AM
chromecat
5
06-14-2004 11:47 PM
dreamer
05-17-2004 11:48 AM
