Trs Transom Install >
Trs Transom Install
Trs Transom Install
Old 04-02-2008 | 08:28 PM
Lofty's Avatar
Originally Posted by scarabfun
transom is smooth so i'll go with cork only. already fixed transom and repainted. thank's
I like to grease the gaskets, it helps them find a good seat. Don't over grease, just get the surface wet.
Lofty is offline
Old 04-02-2008 | 08:29 PM
Lofty's Avatar
Originally Posted by jholick
What is the amount of torque specified for transom bolts?
Without looking I'de sat 75 - 80.
Lofty is offline
Old 04-02-2008 | 08:53 PM
Originally Posted by Pismo10
I agree, use nothing, the stock gaskets work well, just fix that. Why dont you like 4200?
I like it-just not for that application
Westcoast is offline
Old 04-03-2008 | 06:07 AM
Full Force's Avatar
I read somewhere that you torque to 55lbs.. is that right?
My boat had some sealer on the gaskets from the factory, if not 4200 what about a little regular silicone sealer, I am a little uneasy about using nothing... I am doing the same thing as scarabfun..
Full Force is offline
Old 04-03-2008 | 06:44 AM
Registered User
55 is the factory spec.
Torque gradually in a criss-cross pattern.
Chris Sunkin is offline
Old 04-03-2008 | 06:23 PM
i found today in a mercruiser manual to torque to 25 fl.lbs. it also say's to start in the middle then go up and then down.
scarabfun is offline
Old 04-03-2008 | 07:23 PM
Registered User
TRS? Merc factory manual?
Old 04-03-2008 | 07:35 PM
Full Force's Avatar
I have the TRS service manual here, it says torque to 25-30 ft lbs and start from center and work your way out, just looked it up.
Old 04-03-2008 | 07:55 PM
seem's light i know but i'm going with 25 ftlbs and i'll retork maybe a day later. still uneasy about no adheasive, i might use a very light amount, very light, probably just a below water line silacone. it had some on when i took them off & i think it was factory from scarab. tork spec. was from an orig. tr-trs manual. good luck Full Force.
justice
Do It Yourself, Boating on a Budget
5
02-24-2008 01:16 PM
Poorsche
4
09-24-2005 10:26 PM
orjan
0
07-26-2005 02:32 AM
kmiller
3
07-24-2004 03:47 PM
Waterfoul
07-24-2002 11:24 PM
