Low Ratio Rockers for BBC >
Old 04-04-2008 | 02:49 PM
littledcsrodshop's Avatar
Nothing crazy , & off memory again :
236 246 @ .050
.553 .571
littledcsrodshop is offline
Old 04-04-2008 | 05:34 PM
I am going throught this right now and could not find a single spring set up for those approx. pressures.? I am just running the outer springs for about 45 mins. and then putting the inner spring back in.....I know alot of work, But I'm with you on proper break in is CRITICAL !!! My .02
speedreeder is offline
Old 04-04-2008 | 05:59 PM
Comp 911 single with dampener: 130 - 140 on the seat / 345 - 355 open with 550-575 lift
HaxbySpeed is offline
Old 04-04-2008 | 09:03 PM
Your 130 is still alot on the seat for a new cam break in. Mine is at 80-90 lbs. on the seat. This is plenty for opening and closing on just break in. I did also price the reduced ratio rockers and tried to find some to use..I might just buy some then I could rent them out for everyone to use.?
Old 04-04-2008 | 09:21 PM
It's not the seat pressure that'll kill it, it's the open pressure. The 1.5 rockers don't take anything off the seat they just lower the open by not pushing the spring down as far. I usually install the 911's at about 125-130# I break in all my motors on the dyno and have never had a problem. Having said that, about the only time I use those springs is on really tiny cams which limits the open pressures to around 310# I like the idea of the 1.5 rockers but would rather spend the money on a roller cam
Old 04-05-2008 | 10:05 AM
I agree the low ratio's will not help the seat preassure , only the open b/c of the limited lift.... As for the last statment : If I hadn't already bought the flat tappet & lifters & I didn't already have the heads set up , I would penny up the differance & go roller... But now it would cost me another 1k
plus what I already have in the other stuff (& ontop of that I wouldn't gain a ton of HP with my setup ).... So why is it that practicly everything I do in this sport comes down to the same conclusion $$$$$$$$$$$....... Oh well I still love it !!!
ls1nova
Swap Shop
2
07-15-2013 12:26 PM
littledcsrodshop
04-06-2008 01:06 PM
littledcsrodshop
Do It Yourself, Boating on a Budget
0
04-04-2008 02:10 AM
Donzi502
4
04-08-2007 10:59 AM
Ric232
15
03-05-2004 08:44 PM
