Who has repowered to diesel? >
Old 04-04-2008 | 11:16 AM
phughes69's Avatar
Default Who has repowered to diesel?
Has anybody repowered their boat from gas to diesel? What brand of motor did you use and what did it replace? What kind of outdrive do you have and what did you have to change besides the prop pitch?
phughes69 is offline
Old 04-04-2008 | 01:30 PM
I've done about a dozen. What have you got and what are your performance goals?
HaxbySpeed is offline
Old 04-04-2008 | 11:23 PM
phughes69's Avatar
1980 38' Scarab, running twin turbo Mercruiser 454's with SSM II drives. Originally rated at 475 hp, probably around 550. Top speed is about 75 mph. Cruise speed is about 45 mph. My primary concern is better fuel economy with a comparable cruise speed.
Old 04-04-2008 | 11:51 PM
There's no problem getting the same or better cruise speed from the diesels. There are so many different options and variables it might be easier to discuss it over the phone. Give me a call if you want 604 315 0570.
The diesels make tons of torque at a low RPM so you need reduced gear ratios and lots of pitch to take advantage of it. The lower rpm operating range of the diesel will take off some top speed but the midrange will be awesome. The trade off is you'd have to use your boat a LOT in order for the increased efficiency of the diesel to overcome the initial cost of the repower.. Alex
Quicksilver
05-19-2008 11:56 AM
redscarab
9
02-05-2008 07:36 PM
Haulin A$$
10
11-28-2005 07:47 AM
Boomer35
17
09-29-2005 12:12 AM
boot
02-14-2003 02:33 PM
