Derateing the carb CFM with f arrestor
I run K&N's with Extreme tops. As for carb sizing there is a simple formula for naturally aspirated motors;
Required CFM = CID X RPM / 3456 X VE (volumetric efficiency)
If you don't know VE then assume 100% max unless you have an exotic setup where you can see 110% (high rpm's, long duration cams, higher compresssion, geat heads,etc) . Most engines are only about 85% efficient though.
I've actually seen test results (Not from K&N) showing MORE Air flow through an air filter set up over nothing.
whtnordic
Wanted
6
02-24-2008 01:16 PM
tpmarine.com
New Products and Member Discounts
0
07-20-2005 12:04 PM
