interlux paint >
interlux paint
interlux paint
Old 04-14-2008 | 08:04 PM
Default interlux paint
Does interlux paint work,They say nothing will stick to it.And the claim 1or 2mph..Need alot of bottom gel coat work.This mite be a easy fix.
SCARAB98 is offline
Old 04-14-2008 | 10:16 PM
what is the number of interlux are you looking at? We use a lot of it "33" for bottom paint. Nothing sticks because it slowly wears off, So if you pull up on a beach it will wear it off. You do have to primer it first and do the right prep work for it to last.
speedreeder is offline
Old 04-15-2008 | 07:38 PM
i use interlux 2001 epoxy primmer aand epoxy paint 15 years never repainted it i leave it in delaware river all summer .i take boat and use onof wash it down. that primmer works good
bajabob is offline
Old 04-15-2008 | 09:28 PM
The whole idea of interlux 33 is to slowly wash off and therfore nothing sticks to it, So you dont have to get aggresive washing it off, It's designed to come clean easily. The primer seals the gelcoat from getting water under it, I.E. "blisters", And the primer stays on for recoating the "33" years afterwards.
Old 04-15-2008 | 09:30 PM
Scarab, You can use there filler putty and then put the primer on it and then the 33. However it is not very good if you are going to put it off and on the trailer,Sliding on.
SUNSATION 25
Detailing, Painting, & Fiberglass
1
05-20-2008 01:34 PM
bouyhunter
3
04-11-2008 12:27 PM
VetteLT193
12-04-2007 08:56 AM
TINO160
0
02-21-2005 05:17 PM
Pure Energy
04-05-2004 06:57 AM
