Holley Blue pump >
Holley Blue pump
Holley Blue pump
Old 04-22-2008 | 11:51 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Young Performance
The Holley blue is more than enough pump for your power. It will support almost 900 hp. I have never had any luck with them lasting. I use the Aeromortive street rod pump instead. About the same size, but a little more money. If you have it, use it. It will be more than enough.
Eddie.
Eddie I wonder if its because its dead heading at the regulator,if it was on a bypass I bet it might last longer?
Strip Poker 388 is offline
Old 04-23-2008 | 09:26 AM
PatriYacht's Avatar
I have had good luck with Mallory Comp 140 pumps on 700 hp engines. They have been dead headed and still last for years. Not too expensive and they come in a marine approved version.
PatriYacht is offline
Old 04-24-2008 | 12:25 PM
Rob
PatriYacht I also ran a 140, motor plus NOS was 750hp,never had a prob
what about the holley black pump?
Old 04-24-2008 | 07:01 PM
monstaaa's Avatar
c.v products mechanical fuel pump absolutely rules. large inlet, interchangable pressure springs, internally bypassed, billet, degreeable.
for electric nothing beats the mallory. except for a weldon.
as mentioned everything else should be in accordance. and mostimportantly is a rutrn style regulator installed after the fuel rail.
Attached Thumbnails Holley Blue pump-e7.jpg   Holley Blue pump-guido-2-007-large-.jpg   Holley Blue pump-e2.jpg
monstaaa is offline
Old 04-25-2008 | 03:32 PM
Your 700 Hp Engine Will Require .98 Gpm Or 58.8 Gph
You Can Dead Head The Holley Blue,it Has A Built In Relief Valve. Caution Do Not Do This To Long The Pump Does Not Like This.
Jb-fse is offline
Old 04-25-2008 | 03:47 PM
Rob
I was told that the engine requirment of fuel is related to rpm also.
Old 04-25-2008 | 07:59 PM
I also use the CV Products mechanical pump. With the light "blue" spring you can run 750 HP safely at 5.5-6 lbs pressure @ WOT with no need for a regulator. At idle you have about 8-8.5 lbs. All accomplished with 3/8" lines...Dean don't start on my stock lines!
BenPerfected is offline
Old 04-25-2008 | 08:46 PM
monstaaa's Avatar
kids rule
monstaaa is offline
Old 04-25-2008 | 09:01 PM
lakepop
i noticed the pump is mounted above the tank level, they are not disigned to suck only push . This will cause the pump to cavate generating heat, magnets will come unglued causing failure.
lakepop is offline
ak
5
04-13-2008 08:14 PM
jdub
7
03-26-2007 05:06 PM
zitoracing
0
10-15-2006 01:37 PM
Leathl_WS6
8
10-13-2003 04:59 PM
