Run Dry Impeller >
Run Dry Impeller
Run Dry Impeller
Old 04-24-2008 | 12:59 PM
seahawk's Avatar
Default Run Dry Impeller
Has anyone used a run dry impeller in the merc. plastic raw waterpump housing (46-80151a4) If so will it melt the housing if it runs dry?
seahawk is offline
Old 04-24-2008 | 08:16 PM
seahawk's Avatar
seahawk is offline
Old 04-24-2008 | 09:42 PM
jhiguy377's Avatar
was kinda wondering the same thing myself last Fall - Jeff
jhiguy377 is offline
Old 04-24-2008 | 11:06 PM
Default Well
The answer is yes and no. The inside of my old housing was "rippled" ever so slightly, meaning it still worked, but probably wasn't perfect. It doesn't take long running dry for the impeller to get really hot, then when it stops i think it "spot welds" itself to the housing. Start the motor next time (usually when it's a holiday wkd) and it just rips the @$% out of the impeller....
So, no wawa is no bueno
Yellow_ICC_OK is offline
Old 04-25-2008 | 09:09 AM
Downtown42's Avatar
I want to try some just for extra protection in case water flow is light. But I'll never run without proper hose and muffs, cause it will get hot quick.
Downtown42 is offline
Old 04-25-2008 | 05:39 PM
I have not run one, but I asked about them a while back, as I've had some problems with the stock impellers, and even though they say run dry, your not supposed to run them dry on purpose, but are suppose to hold up to periods of loss of water much better than the stock one. Nascat here on OSO sells them.
heavyhauler is offline
onesickpantera
10-12-2007 05:55 PM
Clay Washington
09-15-2007 12:32 PM
scarabnewbie
Classic Offshore
14
08-30-2007 10:57 AM
grand-illusion
2
05-13-2007 11:28 PM
Pantera1
01-03-2005 02:29 PM
