-   -   is There Anyway To Get More Power/speed? (https://www.offshoreonly.com/forums/general-q/185574-there-anyway-get-more-power-speed.html)
simplyforce 04-29-2008 12:16 AM
is there any way to get more power and speed outta my boat for super cheap you know like garage tunning type stuff? i have a 29 force offshore cat with a 598 NA carburated motor it has a single 1050 dominator carb, headers, you know the bolt-ons. just curious
kennyo 04-29-2008 08:26 AM
If you're sportin' a 598 i'm assuming you've already done all the little things.
Croozin2 04-29-2008 08:44 AM
Not to overstate the obvious, but if this is the sport/hobby you chose to get into, "super cheap" shouldn't be in your vocabulary!! Jus sayin...:D
Big Cliff 04-29-2008 09:14 AM
Most of the speed is in the setup. What prop? What drive? What prop depth to sponson?
Is that motor aluminum headed? Good intake?
CB-BLR 04-29-2008 09:25 AM
I think you can almost always find speed/performance by playing with the prop.
Chris
Chris Sunkin 04-29-2008 09:36 AM
Yeah but a new Hering peobably wouldn't fall under the category of "cheap" Having said that, you probably couldn't find 3mph or so for less $$. Plus, it won't increase your fuel consumption
Here's a thought- have you blocked & wetsanded your bottom?
Planetwarmer 04-29-2008 11:14 AM
The cheapest way to make a boat go faster that I found was to loose weight!
Chris Sunkin 04-29-2008 11:43 AM
Very true, but you have to remove any significant weight proportionally. Altering your boat's center of gravity too much can cause odd handling issues.
BlackJack58 04-29-2008 02:00 PM
Yeah --just push that fat chick off the back of the boat and you will go a lot faster. Doesn't cost a thing.
Not having her fat bottom in the boat may adversely affect your center of gravity, but at least you won't have any awkward explaining to do to your friends...:D
simplyforce 04-29-2008 06:35 PM
ok whats a hering? and im running a labbed 28p 4blade prop with a xr drive w/ a -2 inch shorty lower. i have not sanded the boat and absolutly no fat chicks either ha ha
