water routing >
water routing
water routing
Old 05-09-2008 | 07:54 AM
randy carlson's Avatar
Default water routing
Getting ready to put my now fresh 502's back in, going with 496 short riser exhaust, question is with my stock thermo housing early style 4 barbs to exhaust-open between hot/cold. will the 496 riser coming from a closed cooling set up flow enough water out that I can run warm side to bottom of manifold and tee cold side into manifold-riser hose or should I just dump my cold side overboard (cold side has the plastic balls and springs). My concerns are too much water pressure/ not enough flow thru exhaust. I will be spinning them abit faster that I used to be able to. any suggestions? thanks Randy
randy carlson is offline
DONZI
2
08-15-2008 04:25 PM
bcarpman
4
10-16-2006 06:42 PM
2112
3
07-06-2006 06:22 AM
plumbers crack
7
01-02-2005 11:02 AM
CB
4
08-14-2002 11:50 PM
