Imco Water pickup >
Imco Water pickup
Imco Water pickup
Old 05-15-2008 | 10:48 AM
Default Imco Water pickup
Just bught a IMCO adjustable water pickup & would like to know where on the transom is best to mount it. Also how far from the bottom is it supposed to be.
Fast Willy is offline
Old 05-15-2008 | 11:48 AM
Single or twins????
Mount it so the trailing edge is about 1/8" below the hull. You don't want it disturbing the water that is in front of the prop if at all possible.
Griff is offline
Old 05-15-2008 | 12:00 PM
Canada Jeff's Avatar
Here is a pic of mine for referance
Canada Jeff is offline
Old 05-15-2008 | 02:06 PM
It's a single, thanks for the pic. So 1/8" below bottom of boat?
Old 05-15-2008 | 02:22 PM
Your pick up is adjustable right? If I were you, I would mount the pickup so that the highest piont is flush with the bottom of the hull. Then you can alwyas adjust down if you have to.
LZH
Drives and Lower Units
0
02-25-2008 08:18 PM
zimm17
4
05-28-2007 07:08 AM
dualprop
09-11-2006 02:34 PM
duffster
1
06-15-2006 05:21 PM
pwrbotr
03-09-2006 09:38 PM
