installed valve spring height on a 454 mag >
Old 05-20-2008 | 02:45 PM
lake speed's Avatar
Default installed valve spring height on a 454 mag
I have a set of 990 heads being redone off of my 454 mag and the machine shops needs the installed height of the valve springs. I could also use the recommended seat pressure and the recommended psi of the spring when open. I need this asap! help please.
lake speed is offline
Old 05-20-2008 | 04:35 PM
I can you tell you the stock cam specs and they might be able to work off that.
.510/.510 , 220/220, 115 lobe separation.
Griff is offline
Old 05-21-2008 | 07:01 AM
about 1.900 should be fine, thats what mild comp cams springs are designed to run at, spring pressure going to be with spring choice at that height...Rob
ezstriper is offline
traviss
40
09-27-2009 08:15 AM
Tricky919
11
06-10-2007 12:44 PM
2112
16
04-16-2007 08:27 PM
MOP
1
06-11-2006 10:57 AM
ThirdBird
12
03-29-2005 09:25 PM
