Kind of bad luck to day, or maybe not?? >
Old 05-27-2008 | 05:08 PM
Hi Guys
Look like I had luck, fixed the water pump. Fired her up today let her run for one hour, evrything seems ok. No leaks, the engine sounded great, oill was good. The tempratur and oil
pressure was perfect. So far so good
Monaco20 is offline
Old 05-27-2008 | 05:16 PM
Biggus's Avatar
I'd still change the exhaust hoses. I've had them delaminate from the inside, blocking the flow out water exiting the pipe causing major problems. Also check the flappers, they are probably toast.
Biggus is offline
Old 05-28-2008 | 06:02 AM
I will change the exhaust hoses during this week.
Thanks for all the comments
Today is a nice sunny day in Oslo (Norway) leaving the office early to go boating
Monaco20 is offline
Old 05-28-2008 | 05:49 PM
Turbojack's Avatar
I second this from experience. Also I would change the oil. Then just watch it. Make sure you hunt down the parts of the impellor if any blades are missing.
Turbojack is offline
X-Rated30
03-13-2006 10:14 AM
bford1
06-01-2004 11:16 AM
ragtop409
07-27-2003 07:55 PM
vagrant
05-01-2003 12:50 PM
