Blower Upgrade >
Blower Upgrade
Blower Upgrade
Old 05-23-2008 | 09:41 PM
Originally Posted by RJBBC
How many hours did you put on the motors with this setup? Thanks for the cam profile info, I will look into it.
about 150hrs. never skipped a beat
smokinbob is offline
Old 05-23-2008 | 11:09 PM
Tyler Crockett recommended the 250 and 1050 carb. Predetonation is a big concern. I am not familar with H20 injection. Would that be needed with 5 pounds of boost? Should I consider less boost? The blower upgrade kit would include an adjustable fuel regulator, blower, carb, oil cooler, fuel pump, fuel line and throttle bracket, billet flame arrestor and MSD ignition. Anything else needed?
You don't need water injection with 5# of boost. Your static comp ratio is about 8.9:1. Keep the boost at 4-5# and it should be fine on 93 octane.
I would also go with a 250 blower over the 177 if you are buying something. The 250 will make less heat and reduce the risk of detonation. Have Nickerson set up a carb for you.
Griff is offline
Old 05-24-2008 | 06:13 AM
RJBBC's Avatar
Registered User
Griff,
How about retarding the timing to 18 degrees total advance and running on 91 octane? Is that possible with this setup? What are the trade offs of retarding the timing to prevent detonation on lower octane fuels? Tyler will sell me a blower prepped 1050 carb, I will ask him if it is from Nickerson.
RJBBC is offline
Old 05-24-2008 | 06:14 AM
RJBBC's Avatar
Registered User
Sounds like I need to buy the blower kit.
RJBBC is offline
Old 05-24-2008 | 07:13 AM
Total agreement here. 575sci has a 256 stock, an 871 would have been a better fit with its 7.5:1 low compression. With your higher compression the 256 should be fine. As someone else also mentioned you will most likely want another cam for a supercharged application. I am sure Crocket would have a few grinds in mind. Keep in mind your hatch clearance. If it does not clear do you really wanna cut it? Are you sure you want to loose the FI?
If it were me...I think I might just trade up for more power...most of the time its cheaper.
JRider is offline
Old 05-24-2008 | 01:40 PM
Griff,
18*?????????? is not even close to enough timing.
28-30* is probably the minimum total timing you want to run. If you only have 91 octane available, then I would try to keep boost around 4#. TC should have a good idea of what you need for the carb and it should work fine.
Here's some good reading from the Holley web site
http://www.holley.com/data/TechServi...ech%20Info.pdf
Griff is offline
Old 05-25-2008 | 07:20 AM
RJBBC's Avatar
Registered User
How to get to 600HP on a budget is a major influence in the decision to supercharge. Supercharging what we have seems to be significantly less money than building a large displacement NA from scratch.
RJBBC is offline
Old 05-25-2008 | 07:22 AM
RJBBC's Avatar
Registered User
Griff,
Thanks for the technical info on superchargers, very informative.
RJBBC is offline
Old 05-25-2008 | 06:24 PM
Vinny P's Avatar
I hate the winter!!
Hey Rob,
Cant say I can help with anything about superchargers. I have very little experience with them. I can say this... Do you think you have enough room in front of your crank for that big wide blower pulley? Mine is the same boat as yours and mine wold be real tight, if not impossible.
Vinny P is offline
Old 05-26-2008 | 05:21 AM
RJBBC's Avatar
Registered User
Originally Posted by Vinny P
Hey Rob,
Good point Vinny. It appears some fabrication will be necessary. I think a little saw action and some rearrangement of a crossbracket for the seat will be needed. I think it can be done without too much hassle. Although these projects all seem easier to me because I watch someone else struggle through it.
RJBBC is offline
