I need to test my CMI for my 525 >
Old 05-20-2008 | 08:12 PM
25 hors la loi's Avatar
Default I need to test my CMI for my 525
Hello all ,
i just remove my CMI sport tube from my 525 efi , and in exaust port number 3 and 7 i found some water drop (it`s not water because when i winterizing my block last fall i put 4 gallons of RV antifreeze and not water in the last minute running)
What i done so far is ....fill up the headers with water ...and after that pressurise with air at 7 psi .....and put some heat with propane torch ....and i see no water coming ....
i am little lost here .... i put not enought heat ? , tomorow i will post more picture
if i am not clear feel free to ask
Regards
25 hors la loi is offline
Old 05-22-2008 | 08:04 AM
Ok , what i found so far is , nothing special , i will reinstall the header , and after some running hour , take off and check again .....because after fill up with water and pressurise at 7 lbs , i use propane torch to heat up and nothing happen
Attached Thumbnails I need to test my CMI for my 525-p1200094-large-.jpg   I need to test my CMI for my 525-p1200095-large-.jpg   I need to test my CMI for my 525-p1200099-large-.jpg
Old 05-22-2008 | 08:05 AM
Anybody have ever do a test like this ? , i am wrong ?
Christian
Attached Thumbnails I need to test my CMI for my 525-p1200101-large-.jpg   I need to test my CMI for my 525-p1200102-large-.jpg
Old 05-22-2008 | 10:02 AM
tssteph's Avatar
I have. I used air alone and no water. I put 20 psi on the whole system when I did mine, I let it site all night under pressure. By just testing the header you are assuming the problem can only be the header. What about an intake leak or head gasket leak on that cylinder? I would say your header is fine.
By the way mine tested fine under pressure but looked like this the pics below. Problem ended up being the flaps in the exhaust, or lack of.
Attached Thumbnails I need to test my CMI for my 525-pic00520.jpg   I need to test my CMI for my 525-pic00523.jpg
tssteph is offline
Old 05-22-2008 | 10:40 AM
Thanks for your reply tssteph , my 525 is a close cooling , and the level of my reservoir stay ok , this is why i think is not a gasket , condensation is possible ? , this is why i think to put back header , and made some driving time and remove and have a look in middle of the summer , what you think about that ? , sorry for my bad english
Regards
Old 05-22-2008 | 12:09 PM
Velocity Vector's Avatar
Crazy Energy
The oil temp should be around 220-230 degrees to keep the condinsation out of the oil. If you don't have a oil temp gauge you can use a heat sencing gun and shoot it at the oil filter to get a reading. Good luck
Velocity Vector is offline
Old 05-22-2008 | 12:14 PM
Thanks Velocity Vector for the reply , i have a oil temp. gage , and my oil always stay at around 220 , but my concern is the little drop at the exaust port ??? ....
Thanks again
Old 05-24-2008 | 11:27 AM
Crazy Energy
Thanks again
What did the 3 & 7 plugs look like?
RJ1340
09-11-2011 12:41 PM
risky
Active Thunder
5
02-21-2007 01:23 PM
teaguecustommarine
New Products and Member Discounts
8
09-01-2006 05:52 PM
SF31SONIC
3
08-22-2006 08:15 PM
Roger
General Racing Discussion
0
12-06-2005 09:48 PM
