oil temp
Old 05-22-2008 | 12:10 PM
bcfountain's Avatar
Registered User
Default oil temp
what temp should the oil be on my 1994,502mpi mag?i am seeing around 240.if i run it hard it can climb to 250.too high?oil cooler clean,block clean,new water pumps.at what temp does oil start to break down?thanks
bcfountain is offline
Old 05-22-2008 | 12:32 PM
Registered User
Sounds perfect. Hot enough to cook off moisture but not by much. You should be using a high-quality synthetic that will give you protection to well over 300 anyway.
Chris Sunkin is offline
Old 05-22-2008 | 01:19 PM
offthefront's Avatar
for sure Synthetic at 240+ ...is this a stock 502 cooler ?
offthefront is offline
Old 05-23-2008 | 07:20 AM
bcfountain's Avatar
Registered User
Default cooler
stock cooler w/power steering .
Velocity Vector
0
04-03-2008 01:45 PM
GoCiggie31
7
08-19-2007 06:07 PM
powerguy
5
08-04-2002 07:44 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
kook
05-15-2002 06:05 PM
