Steering problem after Arneson convertion >
Old 11-08-2008 | 03:57 PM
Originally Posted by Turbojack
I can not believe they did not tell you what side to put cylinder on. I guess with a dual engine set up there is a cylinder on each side, so maybe they did not think of this problem with just 1 drive. Did changing fix the amount of turns, lock to lock?
The kit was delivered as a fixed kit with the cylinder on the port side from Arneson (premounted brackets, service holes, fittings etc). We had to rebuild a lot (make new brackets, drill a new service hole etc. ) to get it on the starbord side...... The amount of turns is the same.
Attached Thumbnails Steering problem after Arneson convertion-port1.jpg   Steering problem after Arneson convertion-prt.jpg   Steering problem after Arneson convertion-strb.jpg
Sunnydays is offline
Old 11-08-2008 | 07:04 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Sunnydays
Hydrolift in Europe, Norway:
http://www.hydrolift.com
Thats alot of motor and boat,keep us posted
Strip Poker 388 is offline
Old 11-08-2008 | 08:45 PM
how fast does she go ?
how doe's the handle when turning at slow speed or any speed ?
mikebrls is offline
Old 11-09-2008 | 05:40 AM
75MPH so far. But just started testing. We have about 35% slip..... We have a job to do dialing her in.
She seems to handle turning very well. No big difference from the Bravo XR. The speed drops a bit offcourse
when turning, a little more than the Bravo.
Old 11-09-2008 | 11:23 AM
Pretty trick stern anchor....Is that a custom exhaust on the port side?
Westcoast is offline
Old 11-09-2008 | 05:01 PM
No, they tried to combine the exhaust and the swimplatform but it did not work. Exhaust goes throug its own holes on each side. They kept it this way as a design gimick.
Carlo
Cigarette
3
07-04-2008 08:04 AM
SteveB
1
09-16-2007 11:25 AM
timucin
7
06-30-2003 11:36 PM
patrick22309
4
06-21-2003 08:54 PM
