Fueling issue:  Need opinions/ideas where to start troubleshooting >
Old 06-04-2008 | 10:16 PM
  #31
Originally Posted by formula 382 sr-1
The cover to the tank should be sealed. You should only have the service port not sealed .
Yes, we dont want water soaking into the foam that surrounds the tank. Baddogs boat has a pirelli rubber floor, that looked pretty sealed. But that water has to be getting in somewhere, access hatch, etc.
It sounding to me like a clogged pickup tube or something similar.
MILD THUNDER is offline
Old 06-05-2008 | 12:21 AM
  #32
Check your mech fuel pump. Mine just went out due to a faulty (worn) actuator arm. My boat is a '96 with a 502 MAG running the VST and I thought the problem was in that vapor tank, but turned out the mech fuel pump was the issue. It was doing the same thing- died then sputterred. Also was sputtering in the top rpms before which led me to clean the VST thinking it was f-ed.
Check my post in the "Do it Yourself" section of the Technical Forums. I got some pretty good info. Good luck.
bsirk is offline
Old 06-05-2008 | 08:18 AM
  #33
obnoxus's Avatar
Charter Member #1171
OK,,, just deleted my last post so no one took my comments the wrong way.
The jist of it was,,,,,
Read the first post ,,,TWICE ,,,, I MISS STUFF THE FIRST TIME I READ IT TO,,,
Read all susbsequent posts by the thread originator to see the direction the troubleshooting is going.
Ill leave it at that !!!!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-05-2008 | 11:32 AM
  #34
Here's the port. Seems to be less water down there than yesterday. Going to siphon it out now and try to clean all the electrical connections down there and inspect the pickups.
Picked up new fuel filters as well. I'll keep the thread updated as I progress today.
baddogz28 is offline
Old 06-05-2008 | 11:37 AM
  #35
Couldn't upload the attachment...
Had to host it myself.
Old 06-05-2008 | 11:45 AM
  #36
obnoxus's Avatar
gonna have to suck all that bad fuel out of there or youll fill the new filters with water right away
obnoxus is offline
Old 06-05-2008 | 07:38 PM
  #37
10x's Avatar
10x
10x
Sounds like the problem is in fuel starvation, since you said the line had no fuel leaking out of it when you took it off. Are you "sure" that there's no water in the fuel??? That will make the difference of it not running when it has fuel pressure.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
  #38
Dude,
Listen to Big D (Obnoxus) he is the man and know his shinizzle!
Magic Medicine is offline
Old 06-05-2008 | 09:23 PM
  #39
Bigracks's Avatar
Size Matters
Originally Posted by Magic Medicine
Dude,
Bypass the main tank and use a small doner tank small fuel, bottle etc, be carefull as not to spill fuel. if it starts and runs on the doner tank its got to be in the pickups in the main tank. My motors vaper lock on early season fuel but it usalley happens when hot and hatch closed after running hard for 15 miles or so.... my bet it is in the pickups or water in fuel
Bigracks is offline
Old 06-06-2008 | 12:09 AM
  #40
MrCIG's Avatar
Charter Member#330
Check the vent on the fuel tank on the side of the boat. Spiders make nests in there and that will cause you problems also. Usually just when you go to fill, but i have seen motors starve for fuel because of a clogged vent also.
Mark
MrCIG is offline
