Engine Install? >
Engine Install?
Engine Install?
Old 06-05-2008 | 03:26 PM
Default Engine Install?
On the flywheel cover to transom assembly mount what is the order of the washers, spring, spacer on the bolt. I've seen the schematic that shows it but it doesn't show the flywheel cover mount. I need to know the order with relation to the engine mount.
CN24 is offline
Old 06-05-2008 | 07:09 PM
Glue the fiber washer on the inner transom plate. Place the "spring" washer inside the fiber once glued in place.
Lower the engine in place. Stick the big washer on the bolt first, then the spacer. This places the head of the bolt up where it's easier to get to. Ths spacer should make contact with the bellhousing motor mount.
1BIGJIM is offline
Old 06-05-2008 | 07:44 PM
Thanks. Just what I was looking for!
CN24 is offline
Rage
Nordic
9
10-11-2005 11:56 AM
cdog
05-05-2005 08:52 AM
mlitefan
01-13-2005 07:13 AM
MKast
12
04-28-2004 09:15 AM
