Throttle Adjustment
Larry
Larry
Yes, The reason for the three holes. Adjustment. Some of the stock merc. setups have piece for the increase.
Mike
I had the same problem. Look at the pic in post #6. Click on it to make it larger. You will see the the Alum. Piece I made and bolted it to the carb linkage to extend the cable out fruther. You need to move it about 3/4 of an inch. You'll have to play it a little. Not very hard.
I would not mind having the shorter throw, but i have hardly any movement before I am WOT. It is very annoying when I am trying to cruise at 3000. Your setup looks killer though!
