Thermostat issue? >
Thermostat issue?
Thermostat issue?
Old 06-22-2008 | 05:19 PM
Default Thermostat issue?
Not sure if I actually have a problem or if I am overthinking it.
I have a pair of 350 mags in my 292 and the port engine runs just fine but the temp will come up to 180 and only drop off maybe 5-10 degrees when the thermostat opens.
The starboard side will come up to 180 and drop back to 160 when when the thermostat opens.
I have switched sending units, 2 thermostats and put new impeller in the port side but it just does not drop off like the other.
Like I said, both run great, neither overheat or anything but I am wondering if I am missing something or worrying about it for nothing.
Any other ideas would be greatly appreciated.
debcod2 is offline
Old 06-22-2008 | 05:32 PM
offthefront's Avatar
check for debris at the oil cooler ... could be restricting flow making it run slightly warmer .. could be a piece from an old impeller or just debris you have picked up ...m
offthefront is offline
Old 06-22-2008 | 05:41 PM
Good idea, I never thought about looking there.
debcod2 is offline
Brandon
3
10-29-2007 12:01 PM
formula1
5
08-09-2006 12:26 PM
russ
0
07-21-2005 04:35 PM
Perfectmix
9
05-06-2004 08:32 PM
