Leaking oil at cruising speeds >
Old 06-24-2008 | 11:04 AM
Default Leaking oil at cruising speeds
The oil is dripping down the oil filter so of course I thought the filter was bad. I replaced it and got the same result. Hoses and connections all look good. Has anyone ever broke or cracked an oil filter mounting plate?
NickOTeen is offline
Old 06-24-2008 | 11:14 AM
Jerry B
You may want to get some oil dye to help pinpoint the leak.
Jerry B is offline
Old 06-24-2008 | 11:29 AM
Bad oil filter housing flange surface? Maybe you're just overtightening the filter causing the gasket to blow out. I've never had a filter leak at the housing flange.
ThirdBird is offline
Old 06-24-2008 | 11:42 AM
bcfountain's Avatar
Registered User
Post oil filter flange
did you check the gasket under the oil filter flange?
bcfountain is offline
Old 06-24-2008 | 01:09 PM
Thanks guys. By the time I found the leak, and replaced the oil filter I ran out of time so I will investigate further this weekend. I definitely did not over tighten the filter though. It's really the strangest leak I've seen. It took two of us over an hour to find. Seems like I'm losing about 1 quart per hour of running time.
Old 06-24-2008 | 02:43 PM
Registered User
Maybe a double-gasket. They can get stuck on there pretty good.
Chris Sunkin is offline
Old 06-24-2008 | 02:55 PM
hunster's Avatar
What Chris said. Just had a friend who had to change his oil by himself and left the old filter sealing ring on and toasted a 454 by the time he found the leak and problem. At least you are better off.
hunster is offline
Old 06-25-2008 | 07:08 AM
What type of engine, and is the filter in stock location our is it remote?
Budz Motorsports is offline
Old 06-25-2008 | 08:40 AM
Procharged 350. Filter is in remote location.
Old 06-25-2008 | 08:44 AM
I was extremely lucky myself.... It's not a double gasket problem either. The plate the oil filter sits on was smooth as can be and the old gasket came right off.
