thunderbolt ignition wiring >
Old 07-03-2008 | 04:20 PM
Default thunderbolt ignition wiring
Hello,
I'm going to change my distributor and need a wiring diagram to install ,it's a thunderbolt 4 with a 22a advance module. it has purple and gray wire's. Also do I need to ground anything the set the base timing ,this distributor is around a 1988 module which is new. Thanks Alec
alecsammy is offline
Old 07-04-2008 | 03:44 PM
offthefront's Avatar
Grey is neg coil ...Purple to Positive coil ...no ground to set base timing ....m
offthefront is offline
Old 07-05-2008 | 07:30 AM
Don't worry about base timing. Bring the motor up around 3000 rpm and set the total advance timing. I have mine set at 37* Some guys only like 34 - 36 . I have the v 24 module and only get 20* advance out of it.
Noise Pollution is offline
Old 07-05-2008 | 07:35 AM
I found my old manual . Thanks
floatingphil
6
09-27-2020 11:03 AM
Gordo
4
08-23-2008 09:09 AM
bp37
0
07-01-2005 09:54 AM
ASD-6
5
08-07-2002 06:38 PM
BAD-HABIT
0
04-10-2002 04:11 PM
