gauge light bulbs >
gauge light bulbs
gauge light bulbs
Old 07-03-2008 | 07:40 PM
Question gauge light bulbs
Replaced all my gauges last year with Gaffrig and the bulbs have these red rubbers on them. Well after seeing other gauges that are alot brighter than mine at night, is there something that I can change with the bulb to make it easier to see at night. It is just too dim. Thanks for the help
team Tickfaw is offline
Old 07-03-2008 | 07:47 PM
scottc's Avatar
Try getting the red 194 bulbs, They also come in blue. You might need to install a dimmer though or a reistior of some sorts.
scottc is offline
Old 07-03-2008 | 08:03 PM
Thanks I will look into that.
Old 07-03-2008 | 08:19 PM
Try LED's, they are avaiable in a number of the standard sizes now and much much brighter
x7734x is offline
Old 07-04-2008 | 05:35 AM
it won't matter. if theyre gaffrig, none of the gages will work in 6 mos anyway or be so fogged up with water you won't be able to read them. when that happens just get ones that have the lighting you like.
stevesxm is offline
Old 07-04-2008 | 07:32 AM
BillR's Avatar
OSO Moderator
Gaffrig or Livorsi?
I've had Livorsi gauges for years. NO issues.
Now that Gaffirg (not livorsi gaffrig) stuff may be different
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 07-04-2008 | 09:15 AM
i took perfectly good original 10 year old gaffrigs out of my top gun and replaced with new gaffrigs from the mfg in chicago area a year ago and have never seen such worthless junk in my life. they say gaffrig on them. not livorsi
stevesxm is offline
Old 07-04-2008 | 01:21 PM
You are right on the fogging. It was one of those things that was a good deal price wise that turned out not to be so good afterall. As far as working, the only one I have problems with is the port tach. Will do fine then just starts losing rpm, bounces alittle then quits. Give it a good smack and she starts working. I am going to order a few led's and try them next week.
Hello there Bill. remember us from our trip to Little Creek? Have not spoke to Macklin in awhile but we are supposed to come back up around Christmas.
Thanks guys for the ideas.
Old 07-05-2008 | 07:30 AM
Try Livorsi. I believe they have the led bulbs you are looking for. Try part #LM1012MB-R-BK I also found the wedge style bulb in led also. Part #529411 from Ancor marine products. Available at West Marine. Be aware that most led bulbs are not always brighter, but will emit a much whiter light, use less amperage and last hundreds of hours longer.
ROTAX454 is offline
Old 07-05-2008 | 07:50 AM
BillR's Avatar
OSO Moderator
ABSOLUTELY! Will be good to see you again!
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
