circulating pump seal
I had a problem with too much water pressure "80 lbs" 502 mpi at one point water was leaking around water pump at high speeds. I got pressure issue resolved around 28lbs I think. Any way am I correct once the water pump leaks it's history ? I'm never replaced the pump because it was new. Now getting water in bilge don't see it coming from weep hole but thinking it may be leaking at speed. Thanks for any advice
