Synthetic Motor Oil or NOT ???
#31
#32
I was just treated to an excellent presentation by Bill Maxwell of Exxon/Mobil, who is considered by many to be "the father of Mobil One". His experience goes back over 40 years, including some mistakes that were made along the way. Amazing stories. The key points of his talk:
I'm a believer. I've seen Mobil One 75w90 come out of a transmission intact, even after it got so hot that it melted the solder out of a scavenge screen.
- Rather than sift through tons of crude oil looking for the molecule(s) you want, and having to settle for some you don't want as well, synthetics give you the ability to create only the molecule(s) you want - and nothing else.
- Mobil One has learned (sometimes the hard way) that additives that work in mineral-based oils rarely work the same way (if at all!) in a synthetic. Synthetics require their own, highly-specialized additive packages. Latecomers to the synthetic game are still learning this lesson.
- For marine use, there is no better oil in the world than Mobil One V-Twin 20w50. It is basically the toughest oil on the planet, and perfectly suited for hard-working marine engines.
- Racing oils such as Red Line and Royal Purple can be deadly to engines (and outdrives!) that do not see extended periods of high temperature (230+ oil temp), or are stored for any period of time (even just a few weeks). These are almost pure ester-based oils, and any water or condensation present in them will cause the esters to break down into their original components - alcohol and ACID!
- Mobil One SHC (Sythetic HydroCarbon) grease is fine for any marine application, and is waterproof.
- Mobil One oil filters are manufactured (by Champion filters) to higher standards than even OEM filters in terms of both filtration ability AND minimal flow restriction.
It's additive package is amazing with ZDDP levels of 1600 ppm. Ouutstanding detergency and it's is built for engines that require long termed stoarage.
Still my favorite for engines that can handle a cst@100*C of 22...it's actually close to a "55" wt oil. Fine for most any offshore application.
I still like Merc's HP gearbox lube...and might give M-1 75W-90 a try.
#33
You were the one who turned me on to V-Twin 20w50. I had cases of it here at work available at no charge, and was using M1 15w50 instead. This was the oil recommended by Innovation/Volvo Penta for my 540/600's. Since I switched to V-Twin, I've noticed significantly more consistent oil pressures. Thank you!
I sent this thread's link to Bill Maxwell. Maybe he'll comment....
#34
#36
Kendall 20w-50
"Kendall GT-1 High Performance Motor Oil is a high-quality engine
oil specially designed for use in gasoline engines operating under
high-temperature or severe driving conditions, as well as in
competition engines and high-performance street engines. It is
formulated to provide excellent wear protection, to minimize the
formation of sludge and varnish, and to resist viscosity and
thermal breakdown even in severe service. It also protects
against rust and bearing corrosion, and has good foam
resistance. The SAE 20W-50 viscosity grade is fortified with
additional zinc dialkyldithiophosphate (ZDDP) additive to provide
enhanced wear protection and oxidation resistance for use in the
most demanding applications. It is particularly recommended for
use in turbocharged engines and in high-performance engines."
Happy, Happy, Joy, Joy!
#37
Kendall 20w-50
GT-1® High Performance Motor Oil
Typical Properties
SAE Grade 10W-40 20W-50
Density, g/cm3 @ 15.6°C (60°F) 0.873 0.883
Density, lbs/gal @ 15.6°C (60°F) 7.27 7.35
Color, ASTM D1500 3.0 3.5
Flash Point (COC), °C (°F) 227 (441) 230 (446)
Pour Point, °C (°F) -33 (-27) -30 (-22)
Viscosity,
cSt @ 40°C 108 175
cSt @ 100°C 15.3 18.6
SUS @ 100°F 559 913
SUS @ 210°F 81.9 94.9
Viscosity Index 150 120
Cold Cranking Viscosity, cP 6,600 6,600
@ (°C) (-25) (-15)
High-Temp/High-Shear Viscosity, cP @ 150°C 3.9 4.8
Sulfated Ash, ASTM D874, wt % 0.94 0.98
Total Base Number (TBN), ASTM D2896 7.8 7.8
Phosphorus, wt % 0.077 0.108
Zinc, wt % 0.085 0.119
1080 ppm of Phos
1190 ppm of Zinc
Compared to Valvoline VR-1 conventional...Zinc-1300ppm Phos 1200
Comapred to M-1 Silver and Goldcap= 1200 ppm Zinc and 1200 ppm Phos
Compare to M-1 V-twin which has 1600 ppm of both Zinc and Phos. ...gotta love overkilll
Compare Redline 1400ppm Zinc and Phos
Most Amsoil Products (V-twin is higher) are around 1150 ppm of zinc and phos
#38
Mobil-1 V-Twin...Kinematic, cSt @ 100°C is really 17.7
V-Twin $11.50/qt
Kendall $3.95/qt
Adds up when I go through 22 qts. and then some for top offs.
V-Twin $11.50/qt
Kendall $3.95/qt
#39
They would never overbuild on the viscosity.
Ken
