weiand blower pulley >
Old 07-21-2008 | 02:52 PM
Default weiand blower pulley
putting on my weiand 177 blower and cannot seem to find a lower crank pulley that will work, this is a marine kit for a mrec, thru 1995, with a steel factory pulley. The blower pulley will not go thru the factory pulley because the the outermost groove is to small in dia. called weiand 3 times have no got anywhere they said try a aluminum, so i got a march 3 groove, matches the factory pretty close and still will not work, transdapt makes one also and is a little bigger buy don't want to buy another and still won't work...just wondering if anybody else ran into this,,,if I had part # of on that I knew would work I have no problem getting that,,,just hate to get another pricey paper weight...thanks Rob
ezstriper is offline
Old 07-21-2008 | 05:02 PM
I have the tech sheet with Weiand part numbers for 6 and 7 inch bottom pulleys. Which one are you looking for? The bottom one on my motor is 7" aluminum from Merc. Try the Bam Marine site for the Merc part if all else fails.
Old Navy is offline
Old 07-21-2008 | 09:12 PM
I need a 3 groove pulley that will work with the weiand blower pulley and line up with the factory merc p/s, alt, water pump,this kit was supposed to work with the factory steel lower pulley but does not with the steel one that was on my boat...can't be sure it it's original ?? thanks Rob
Old 07-22-2008 | 04:37 PM
My GenV 525sc has an aluminum lower blower pulley that is a 10 rib serpentine. The steel pulley for the V belts is a Merc #52181 @$64.10 (From BAM Marine website). Might be the ticket for you-guessing because I dont know what other pulleys are on the motor.
Old Navy is offline
Old 07-23-2008 | 05:17 AM
fastlane40's Avatar
You will have to get the diameter of the ribbed pulley turned down(the part that doesn't fit into the 3 groove pulley).Done it heaps of times.It doesn't need much off.
fastlane40 is offline
Old 07-23-2008 | 05:18 AM
fastlane40's Avatar
I don't use those blowers any more,sold them off.Still have quite a few top pulley's if anyones interested.
Old 07-25-2008 | 11:36 AM
fastlane, what pulleys do you have and what else ? may be interested, thanks, Rob email [email protected]
Ratchet
17
06-18-2020 07:34 PM
Michael Garibay
Wanted
2
10-29-2008 09:11 AM
lakeman2
2
10-24-2008 09:37 AM
ghittner
14
01-12-2006 11:11 AM
Airpacker
4
10-13-2005 10:17 AM
