Upgrading Engine Ideas
#31
Do yourself a giant favor and call Frank aka "10x" he is pretty well known out of Chicago with many of the offshore boaters and has the inside scoop of what is what and who is who with true hi-perf marine engines. I would contact him and ask who he recommends. He and several others have been through a TON OF GRIEF over there in Chicago with marine hi-perf engines. Before you make a decision I would call/talk to Frank. You will find him in the Chicago Powerboat Club section here on OSO.
Just a word to the wise....the last thing you want is finding out the guy/shop you chose to do your engines ended up being a disaster and a ton of grief!
#32
Registered User
On that 540 build- that all sounds good. Couple of things I'd change;
Crane golds instead of the scorpions
Crane Hi6M instead of the MSD
AFR 315CNC's on heads
The new bulletproof Morel hydraulic roller lifter
Make sure the valves are manley or Ferrea, not Eaton
You should be very pleased with that combination. Now, look into drive upgrades.
(P.S.- $13K isn't a giveaway price. I'd shop some other guys on it. Gellner, Eddie Young, etc.)
#34
#35
#36
Registered User
What you do to the drives is dependent on you as much as it is on the boat and power. If you want to do full-throttle holeshots, if you want to do big wave jumping and you don't want to take the time and effort to learn and exercize proper throttle discipline, you'll shred the XR. Driven sensibly, the X upgrade will probably do you just fine. Merc outdrives like to be kept cool (drive shower) they like fresh oil and they like to operate inside their clearance specs. Essentially, you can keep one around with a little common sense on the sticks and regular fluid changes coupled with having them gone through periodically by someone that knows what they're doing.
#37
Registered User
This is my Achille's heel on projects. It's constantly "only $500 more" until I'm into Sterling money into engines that were supposed to be "just warmed up a little".
#38
#39
#40
Registered User
I tried my damndest to figure out a way to make the same kind of power with a head other than the 315 CNC. There just isn't. They only look expensive. There's no better or cheaper way to make that kind of additional horsepower.
