Fresh Water Cool kit? >
Old 08-11-2008 | 01:37 PM
Gordo's Avatar
Charter Member #94
Default Fresh Water Cool kit?
Who makes the best BBC fresh water cooling kit? 540 C/I 9:5 CR AFR cylinder heads.
Thanks in advance!
Abby-someone
Gordo is offline
Old 08-11-2008 | 02:14 PM
We have an accessory kit that incorporates a heat exchanger for closed cooling. If you are looking to just add closed cooling to your existing setup look at Sen-dure or monitor. They both make a good system.
Kirk
ExtremeCustomMarine is offline
Old 08-11-2008 | 02:34 PM
Gordo's Avatar
Charter Member #94
Do you have a link?
Abby-someone
Gordo is offline
Old 08-11-2008 | 02:58 PM
Elite Marine's Avatar
http://www.sen-dure.com
Elite Marine is offline
Old 08-11-2008 | 03:25 PM
Gordo's Avatar
Charter Member #94
Do you have one for your kit? I mean the Extreme marine kit.
Abby-someone
Gordo is offline
Old 08-11-2008 | 05:49 PM
Vinny P's Avatar
I hate the winter!!
I used the stock Mercury kit from my original 454 magnum on my 540. Works great.
Vinny P is offline
Old 08-12-2008 | 12:21 PM
I have a Monitor and have been very pleased. I cool the full setup (block and 496 aluminum manifolds) with a bravo drive and it's restrictive water pickup. No problems with about 35 hours on it this season.
One thing the Monitor touts is that it's a controlled by-pass thermostat setup - I guess it gives full flow through the block even if the t-stat is still closed. Supposed to provide even cooling.
two-rocks is offline
Old 08-13-2008 | 12:19 AM
2112's Avatar
I made my own. Heat exchanger from American Industrial in Illinois (they make Teague's oil coolers). The overflow reservoir is from a company called Lenco. Fittings from IMCO and brackets from local machine shop.
Attached Thumbnails Fresh Water Cool kit?-heat-exchanger.jpg   Fresh Water Cool kit?-overflow-tank-2-.jpg
2112 is offline
CigDaze
3
10-15-2007 11:57 AM
mcraymond3
10
10-10-2007 07:33 PM
jeff32
01-09-2006 07:21 AM
Stormrider
03-04-2005 09:29 PM
Raypanic
Fountain
10
10-15-2003 09:44 AM
