500 efi mystery ? >
500 efi mystery ?
500 efi mystery ?
Old 08-11-2008 | 05:45 PM
mrquad1's Avatar
Default 500 efi mystery ?
does anyone know of a common problem with starting issues on 500 efi motors? my symptoms are very erratic,only seems to be an issue when ambient temps are above 95 degrees.port side motor will crank and fire but immediately die when oil pressures comes up.only have this problem after running and letting boat sit for 1-3 hrs.never has had any cold start issues or running shutdowns. thanks
mrquad1 is offline
Old 08-12-2008 | 10:02 AM
rrentsch's Avatar
Registered User
I have been having a similar problem with my 500 EFI's. My starboard will start fine but after a couple minutes will die and will not start for at least 15 minutes. I think mine is loading up with fuel and when it dries out it will then start. I've found that if i increase the RPM's to about 1500 for 5 minutes or so it will run fine, until i shut it down and sit for a while. Does this sound familiar ? I had'nt thought about it being related to ambient temps. Maybe someone could shed some light on this.
rrentsch is offline
Old 08-12-2008 | 10:16 AM
offshoredrillin's Avatar
check your iac. also have you changed the throttle blade position at all? lil thinkgs can make a diff. you may have to make sure the blades open a bit more.
offshoredrillin is offline
Old 08-12-2008 | 05:16 PM
Raypanic's Avatar
There was a problem that I heard of a few years ago of a "vaporlock" on early 500EFI's something was wrong with the fuel pump or "cool fuel" system. Try searching
Ray
Raypanic is offline
tcm07
10-03-2008 02:00 PM
Elite Marine
20
09-12-2008 05:28 PM
JOJO
8
09-18-2007 01:45 AM
durbin3
3
02-12-2006 03:25 PM
gsmith9898
8
10-20-2005 02:25 PM
