riser ??
Old 08-21-2008 | 09:16 AM
bcfountain's Avatar
Registered User
Default riser ??
i have a 94502mpi mar.has silent choice.i belive the riser is a stock merc,cast ss.on the side of the riser is a hose bung that is capped.it is 180 degree from the outlet on the riser.can i use this port for my water dump ?
bcfountain is offline
Old 08-21-2008 | 01:20 PM
Water dump for what??????? You cannot run stock merc exhaust dry.
Griff is offline
Old 08-21-2008 | 07:01 PM
bcfountain's Avatar
Registered User
Default water dump
i ,my water pressure is highneed a dump port because i am installing a pressure relief valve.since i changed to a newer style bravo,my pressure is high,35-40 at wot.i was looking to use this port at the riser rather than drill a hole in the hull.
NightHawk
2
05-09-2006 01:10 PM
Whiteknuckle
7
02-20-2005 03:58 PM
Danny_Ocean
1
04-20-2004 05:22 AM
baronbob
6
04-05-2004 06:36 PM
migara422
4
03-28-2004 09:15 PM
