Barry Grant carb ? >
Barry Grant carb ?
Barry Grant carb ?
Old 08-23-2008 | 11:15 PM
With no secondary PV, you want about a 10 jet size increase in the secondaries. The PV acts like a jet that opens with a reduction in vacuum. With no PV, you need to increase secondary jetting to compensate.
You need a PV in the primaries but not in the secondaries and the way you have it is fine. If you had a PV in secondaries, it would be open anyway as soon as you were into the secondaries anyway. You're just doing the same thing with more jet and no PV.
Griff is offline
Old 08-24-2008 | 12:32 AM
BY U BOY's Avatar
Ok, I was fouling plugs so I am jetting down to 70's in the primary and 80' in the secondary. I am going to run the boat in the morning and take a plug reading.
I know this is the wrong time of year to jet a carb especially in HoustonI'll deal with rejetting in the fall.
BY U BOY is offline
Old 08-26-2008 | 10:57 AM
You should be able to get the specs from their website:
http://www.barrygrant.com/demon/default.aspx?page=29
RumRunner is offline
Old 08-26-2008 | 12:28 PM
825 is not listed.
1BIGJIM is offline
Old 08-26-2008 | 02:20 PM
BY U BOY's Avatar
Originally Posted by 1BIGJIM
825 is not listed.
Ditto!
BY U BOY is offline
Old 08-26-2008 | 02:24 PM
BY U BOY's Avatar
I am getting some crazy readings on the plugs. 1 and 3 are a little lean 5 and 7 are a little darker than they should be.
2 and 4 are perfect. 6 is lite and 8 is OK.
could it be an air distribution problem with the intake? ZZ502/502 intake.
BY U BOY is offline
Strip Poker 388
1
10-20-2007 03:51 PM
BY U BOY
10-25-2006 04:47 AM
pkspx
2
05-13-2006 06:57 PM
superwrench0166
13
11-14-2005 05:36 PM
BAD-HABIT
14
07-22-2004 01:02 PM
