Boat setup question >
Boat setup question
Boat setup question
Old 08-28-2008 | 10:27 AM
ls1nova's Avatar
Default Boat setup question
Hi guys. I have a question about setup on my boat. The boat really likes a ton of trim. In calm water I can bury the mechanical indicator (spring loaded style). How can I set this thing up so that I don't have to trim so high to get speed out of it? Here's the boat info. 94 33 Powerplay 600ish HP Bravo's, X is 6" below the bottom of boat, Bravo 30" stock props spining 5600rpm
An I not getting enough bow lift out of the props? Do I need shorties? 3 blades maybe?
Thanks,
Frank
ls1nova is offline
Old 08-28-2008 | 11:01 AM
Your drives are pretty deep. I would think your boat is a great candidate for -2" lowers. Today, I also expect you would get some more top end with Mirage props.
BenPerfected is offline
Old 08-28-2008 | 01:39 PM
a lot of it is probably due to the hull itself along with the balance as well, more hook in the hull means needing more trim to get the bow to lift and free the boat, same as the different speeds between hulls with same power..Rob
ezstriper is offline
Old 08-28-2008 | 02:25 PM
Raise the X and problem solved.
Shortys is what you need 2" i think is the max but i would go higher if posible.
That also gives you Bowlift , so i think props be fine.
DareDevil is offline
Old 08-28-2008 | 03:49 PM
Knot 4 Me's Avatar
Anyone know if these hulls like ext. boxes?
Knot 4 Me is offline
Old 08-28-2008 | 04:05 PM
Von Bongo's Avatar
You can get an Imco with a 3" if you buy the whole drive and not just a lower.
Von Bongo is offline
Old 08-28-2008 | 05:46 PM
blue thunder's Avatar
Some of what I have been reading lately suggests you might get more speed with less prop and 1.36 gears. Getting the prop speed up or more blade area is key in the upper ranges of speed, so they say. Just a thought.
blue thunder is offline
Old 08-29-2008 | 12:03 AM
Thats what i had on my 33 PP , year 1990.
Stelling boxes as high as can be and imco with 2" lowers,1:36 gear with 28 Bravo 1's ,twin 650 HP and ran 108 MPH on GPS.
Motors turned about 63-6400 .
Cool handling and everything.
Old 08-29-2008 | 01:46 AM
Mine is a completely different boat but before I put the -2" shorty I could trim it to the moon to free up the boat and now with the -2" shorty all that's needed is 1/2 as much trim and she is more stable @ WFO as well. My X was deep to start with to.
osur866 is offline
showtime83
6
06-13-2008 03:16 PM
Sick Stinger
Northeast US
4
08-30-2007 04:53 PM
rmikea
Nordic
9
06-27-2007 03:30 PM
