engine wont start (mercruser 5.7L >
Old 08-30-2008 | 08:47 PM
Default engine wont start (mercruser 5.7L
Does any one know what to do to start my mercruser 5.7 L after winterizing.
I have done the following:
1. replaced the fuel in ~ 90% of the tank
2. removed and cleaned all eight spark plugs and there is a spark while the starter is cranking
3. removed and cleaned the carburetor it is back in place and I can see two streams of gas shooting down into the both Barrels
I still can not start the engine, knowing that I did not change any original adjustments. Last October when I bought it, it was working but now there is gas coming in and there is a spark but it just does not work.
Please help!
Krzychu is offline
Old 08-30-2008 | 10:30 PM
Talking
Do you have a kill switch, if so is it hooked up? No I am not kidding or being a jerk.....It happens to most of us at one time or another.
orthos1 is offline
Old 08-30-2008 | 10:43 PM
Pump the throttle three times, crank for 3 seconds with throttle closed , pump 3 more times,crank for 3 seconds in idle positon. Continue till it fires. It may take 3 or 4 tries.
By the way spring came and went.
MOBILEMERCMAN is offline
Old 08-30-2008 | 11:03 PM
blkhorse's Avatar
did you check for spark at the plug(actually using plug)? if not replace plugs. cleaning most times is not enough
blkhorse is offline
Old 08-30-2008 | 11:19 PM
BY U BOY's Avatar
open it up to 1/4 throttle and crank for 5 seconds at a time untill it starts.Also put new plugs in.
BY U BOY is offline
Old 08-30-2008 | 11:39 PM
kill switch is up, if it was on, there would be no spark when I try to start the motor, right?
Krzychu is offline
Old 08-30-2008 | 11:40 PM
yes sir
Krzychu is offline
Old 08-30-2008 | 11:58 PM
Do you have spark?
x7734x is offline
Old 08-31-2008 | 12:40 AM
if you fogged the hell out of it, pull the plugs, replace them, crank, pull nclean the plugs repeat a couple times, replace filter/seperater
phragle is offline
Old 08-31-2008 | 01:38 AM
Originally Posted by x7734x
Do you have spark?
Yes I do have spark and gas shooting in
Krzychu is offline
