502MagMPI conversion to Carb >
Old 10-08-2008 | 08:15 PM
  #41
Dave_N's Avatar
Pat,
I know Mark knows what he is doing, but to be honest with you I don't understand his advice. If you had a fuel system problem, the pressure would drop off or at the least become unstable. Plumbing a return hose back to the tank will not help.
As far as the injectors losing power, why not just use a DVOM to monitor it, instead of trying to rig an alternate power supply?
Start looking very hard at the ignition side. I will ship your ECM tomorrow, if you want I will also include a spark tester so you can confirm/rule out loss of ignition. BTW, has the ECM ever been reprogammed? Are you sure the rev limit is properly set? The way you can tell (with a scan tool) if you are hitting the rev limit, is to watch the Fuel Rate. When you hit the rev limit it will go to 0 GPH.
Dave_N is offline
Old 10-09-2008 | 07:02 AM
  #42
when it come to ignitions I would not run anything MSD has, now they have been bought out most of their componants come from china=junk, just pulled all their stuff off my top sportsman race car, my thoughts...MSD may soon die...totally useless...matter of fact I pulled a 7al2 box, pro-billet dist, and replaced with a couple year old mallory unilite that i ran in my checkmate...picked up .500 over what it had ever run with the msd stuff, and they had all the suff back and went thru it this season....Rob
ezstriper is offline
Old 10-09-2008 | 11:59 AM
  #43
Pat McPherson's Avatar
Originally Posted by Dave_N
Pat,
Thank you Dave for checking out my original ECM. Yes, please do send along a spark tester. I think I should test the most basic things.
The feedback I've been giving Mark is that is appears to be fuel related. Everyone that has ridden with me says that the engine sounds like it is starving for fuel.
It could vary well be ignition though; those were the original error codes.
I do believe the ECM I'm using has been reprogrammed with the stock calibration for my engine. No, I don't believe it's hitting the rev limiter because I can trim up and get the thing to rev 44-4600rpm. It's the last 20% of throttle that makes the engine crap out.
Patrick
Pat McPherson is offline
Old 10-09-2008 | 12:51 PM
  #44
Gordo's Avatar
Charter Member #94
This may sound completely off-the-wall, but have you looked at the pick-up tubes in the fuel tanks to look for cracked tube/obstructed pickup filter?
Abby-someone
Gordo is offline
Old 10-09-2008 | 01:06 PM
  #45
Nope, but it is on the to do list...
I have been chasing possible electrical problems because I have had 3 different ECMs on the engine reporting different faults.
I have checked the wiring pin to pin more than once. I have also checked the grounds.
I think the first thing I'm going to do before I go for another ride is tie in another ground to the pin/wire in the connector to the ECM.
Patrick
Old 10-20-2008 | 08:39 AM
  #46
I run a MEFI 1 and it recently went into continuous knock with a second alarm, IC bypass ckt grounded or open.
This sounds like a common result of a failed ECU.
On MSD; I've run their stuff for 20yrs in my drag cars and never had an issue with any of it.
They've got a MEFI4 system for about $1200 that I wouldn't mind trying.
Griswald is offline
davepnola
Do It Yourself, Boating on a Budget
16
05-04-2008 11:55 PM
toolz
5
03-26-2007 07:31 PM
JeffWoods
5
04-24-2004 09:25 AM
thegreygoose
2
03-13-2004 10:35 AM
tssteph
3
04-08-2003 04:27 PM
