Differential Diagnosis on ignition brain >
Old 09-18-2008 | 03:57 PM
2112's Avatar
Question Differential Diagnosis on ignition brain
I get an occasional back fire getting on plane (one side only) but once there it runs well. I of course think ignition problems and have been replacing parts one at a time and have rechecked my timing.
My first question is what are the symptoms of a bad Crane HI-6M ignition? Is it all or nothing? ie it either runs or it doesn't? or can it give intermittant problems?
2112 is offline
Old 09-20-2008 | 11:31 AM
2112's Avatar
Let me simplify my question;
If the Ignition box is defective, does it cease to run completely or can you get intermittent misfires etc?
2112 is offline
Old 09-20-2008 | 03:34 PM
articfriends's Avatar
Easy thing to check-your boats a twin if I remember right-just swap boxes side to side and you'll know. I have a crane box that I run on my boat,it runs flawless but I had other ignition boxes that worked intermittently so its possible,Smitty
articfriends is offline
Old 09-20-2008 | 03:43 PM
Is that the same side that burns more fuel?
Can I pick you brain too?
MOBILEMERCMAN is offline
Old 09-20-2008 | 06:48 PM
2112's Avatar
Smitty,
Thanks, I was hoping to at least find out if intermittent problems were a possiblity before I did that and I will of course do it If I don't solve it with my latest fixes. Unfortrunately, I have used up my last caps and rotors for the billet Holley distributors I am running now and they are discontinued distributors.
Jim, Yes it is the same. Although the difference ,may not be as much as I first thought. I do notice the forward engine taking longer to get up to speed though. I am still going to check into a lighter Driveshaft.
On the to do list for this winter includes Fuel Flow meters so I can really watch it. I am also building EFI engines with O2 sensors in the collectors but they probably won't be ready before the next season.
2112 is offline
Old 09-21-2008 | 06:51 AM
Registered User
I have had sever boats that did that and it was fuel related problems.
clpbs is offline
Old 09-21-2008 | 12:15 PM
2112's Avatar
Boy, I would love to hear you elaborate on this. I have been on the phone with Dean Nickerson and have worked through several potential problems with nothing panning out so far.
I also thought a backfire always killed your powervalves which may not always be true.
Please elaborate!!
2112 is offline
J.B. Marshall
2
06-16-2008 06:54 AM
2112
10
10-14-2007 09:28 PM
offthefront
1
12-27-2005 06:32 PM
