Opinions on Headers
My 945 hp blown 540 reverted water BAD with the lightning headers at idle,I switched to stainless marine 3's with 5" tails. They are big & ugly but work very well,Smitty
Just a reminder for anyone running a procharger,the keith Eickerts do not clear the blower at all,Smitty
It is nearly impossible remember I said "nearly" to run any wet style tail pipe exhaust system at 900plus horsepower. Lightning makes a system with a water jacketed "Dry" tail pipe that will accommodate this application with no problems.
Charter Member #40
Lightning pipe looks like it actually has runners that are close to being equal length. I may be wrong, but as the pipes become more "equal in length" or closer to being a tuned runner length, don't they exagerate the reversion deal as they in effect, suck and blow harder? Cylinder "scavenging" is improved with a "tuned header" as well? In other words, a trade off for better performance upstairs?
Heck, I think that Kennyo's motor was reverting pretty bad at 800hp or so with standard Lightnings.
I think all of the BIG tube ( CMI ,Stellings, IMCO, Stainless Marine ) or what ever work great and dont have issius if installed and COOLED ( again COOLED ) right.
The biggest problem they all have to fail is enuff cooling.
They will all suck water back if the valves are overlaping to make power. But they only damage if not installed right.
My engine always has a little salt in #7 and #8 cylinder.
But never did anything to the engine because its min.
As soon as you run high RPM it will not even get there its from iddle at the dock .
You get the best power out of stellings or Stainless high tourqe III, thats a fact.
But with the Stellings ,alot of cooling is ness. and the aluminum Stainless safe weight and have no cooling issius at all. make the same amount of power.
Just what i learnd for alot of $$$$$$$$ on my $hit.
