496 Sea water pump question >
Old 10-26-2008 | 01:56 PM
Smitty's Avatar
Default 496 Sea water pump question
A buddy just called me for help. He was replacing the impeller in his seawater pump. When he was removing the pump from the motor, he did not notice that it also had a vauum line attached to the pump, and when he unbolted the pump and went to pull it out, it pulled the vacuum line off of whatever it was connected to. We need to know where it goes at the opposite end of the pump.
Thanks,
Smitty
Smitty is offline
Old 10-26-2008 | 07:31 PM
I'm going to venture that it's
something connected to the air drain
system.
http://www.mercruiserparts.com/Show_...r+Drain+System
JaayTeee is offline
Old 10-27-2008 | 07:03 AM
Registered User
it is the drain system the color of the hose matches the color of the ring on the fitting it goes into.
clpbs is offline
Old 10-27-2008 | 12:54 PM
If it is green or grey they are the airlines for the water system. If it is black it is a vent hose for the air system. The vent hose just routes up by the water pump and does not connect to anything.
22 DAYTONA is offline
Old 10-27-2008 | 08:42 PM
Smitty's Avatar
Thanks guys. Looks like it is just a vent hose.
Thanks !!!
Smitty is offline
496mag
19
03-20-2008 09:52 PM
ComfortablyNumb
23
05-16-2006 07:42 AM
kfm237
3
05-27-2005 08:28 PM
ToddW
5
06-17-2003 09:58 AM
blackhawk
06-03-2002 07:11 PM
