What paint to use in engine compartment? >
Old 03-09-2002 | 09:42 PM
CheckmateF1's Avatar
Charter Member #355
Default What paint to use in engine compartment?
I need to repaint my bilge and the flooring on either side of the motor. I'd like to use something that is one step instead of a two part deal. Is there anything that is good and durable and also adheres real good? I'd prefer to brush it on.
SpeedDoc? Anybody?
Thanks, Eric
CheckmateF1 is offline
Old 03-09-2002 | 09:46 PM
I have a buddy of mine that painted his engine compartment with a high gloss rustoleum. It came out great and held up!
That's what I'm planning to use when I paint my engine compartment in the next few weeks.
TomR is offline
Old 03-09-2002 | 10:10 PM
Charter Member #355
Thanks Tom, that's a good idea. And probably cheaper than some Interlux or PPG stuff.
Eric
Old 03-10-2002 | 07:58 AM
Checkmate, you could just lightly sand the engine compartment and gelcoat it. That is all that checkmate does, they use gelcoat that has "Wax" in it and brush it on. By using this type of gelcoat
you will not have have put air barrier on such as PVA so that the gelcoat will cure. I did the same thing with my checkmate when I redid the engine compartment. If I can find the pictures I will post them.
RonS is offline
Old 03-10-2002 | 08:30 AM
pic 1
File Type: bmp
RonS is offline
Old 03-10-2002 | 08:39 AM
pic 2
File Type: bmp
RonS is offline
Old 03-10-2002 | 08:42 AM
pic 3
File Type: bmp
RonS is offline
Old 03-10-2002 | 08:46 AM
Okay, i'm checking to see if this worked, and I don't know why the picture did'nt just come up, and when I try to down load it does'nt work for me. Is it working for anyone else and if it is what do I have to do?
RonS is offline
Old 03-10-2002 | 10:49 AM
Charter Member #355
Thanks Ron, Yes I see the pics. Although I don't know how you got them to come up like that.
I did'nt want to do any sanding. I still have all the wiring everywhere and 2 Kplane pumps and the drive trim pump and steering hardware. Yours looks great but I don't want to remove all my stuff like that.
Thanks, Eric
Old 03-10-2002 | 11:39 AM
28Eliminator's Avatar
CheckmateF1, I think you will probably have to at least scuff up the surface with scotch brit or something, with any thing you use. You wouldn't want to go to all of the work and have it peel off a year down the road.
Nice work RonS, that looks great. Where do you get gelcoat like that. A buddy of mine was thinking of painting his because of the hassle of gel and pva. If he could just get gel and brush it on, that would awsome
28Eliminator is offline
