Need a longer hose. >
Need a longer hose.
Need a longer hose.
Old 11-11-2008 | 09:14 PM
Default Need a longer hose.
Question: I have a 1997 7.4 bravo 1 combo. I bought the boat (22 Scarab) with a blown head gasket. After having the heads cleaned, magnafluxed, and a valve job done, I was going to have the intake manifold checked as well. It had a crack in the exhaust crossover passage (aftermarket Edelbrock). I purchased a performer RPM AIR GAP. Now for the problem the manifold is taller and raises the thermostat housing about an inch and a half higher. This causes a problem with several hoses, the only one I have not been able to rectify is the large outlet hose off the recirc pump to the thermostat housing front starboard ont the housing. Can I find a longer hose. Am I going to have to splice it to extend it (really dont want to do that) or get an aftermarket crossover and t-stat housing. Sorry for the long post.
Runnin Loose is offline
Old 11-11-2008 | 09:40 PM
I had a similar problem. I took my old hose to Pep Boys. They have hose the same diameter with the 90* bend, but with longer legs. I just cut it to length and clamped it on. I'd guess most any auto parts store could hook you up.
Kidnova is offline
Old 11-11-2008 | 09:53 PM
Default Thanks for the info.
Thanks for the info I looked at my local auto parts store. They did not have one that could even be modified but the selection was slim. However after posting I found on here where someone had the exct problem and apparently the 525SC hose is a perfect fit. Thanks.
Old 11-12-2008 | 07:02 AM
There was a post within the last two months about the mercruiser part number. I think it was used on the 525SC?
I think Griff posted the #, send him a PM and find out.
I went to home depot and bought an plastic pipe, cut the hose in the middle and clamped it on.
1BIGJIM is offline
Old 11-12-2008 | 12:34 PM
Merc part # 32-822524
Griff is offline
Old 11-12-2008 | 04:27 PM
is it a rect port intake ? if so i have a nice factory aluminum intake with the bronze liners I'll swap for what you have....Rob
ezstriper is offline
Old 11-13-2008 | 09:11 PM
Thanks for the info. I have the 525SC hose on the way. Ezstriper the heads are oval port. I was looking for a manifold with the bronze crossover no luck for oval port. I figure it should last till next winter as I am building up a new powerplant now. I have been an outboard tunnel guy for a while but this seems like a fun little project and the wife said I finally got a boat you sit in instead of on. Looking forward to meeting some of the members in the houston area.
Robert
Old 11-14-2008 | 09:00 AM
They did not make the bronze lined one in oval port I don't think....all the oem ones were iron...Rob
Knot 4 Me
9
06-06-2008 08:12 AM
wannabe
07-14-2007 07:32 AM
SmallPP
0
02-23-2005 05:56 PM
boatme
04-21-2004 12:41 PM
