Hydraulic roller lifters
Anthony,
There are two different ones, but the difference is that one uses a link bar to hold the two lifters and keep them from rotating, the other uses the stock GM "dog bone" You can use the link bar type in the late model blocks, but not vice versa. Either way, that would not explain the noise on start up. It sounds like the oil is draining out of the oil galleys when the engine is sitting (which is somewhat normal) or for some reason oil pressure is taking a while to build up when you first start them. Next time you start up after sitting a while, watch the oil pressure gauges. The lifter noise really should disappear as soon as oil pressure is up to normal, usually within a few seconds of startup.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
We have not touched our valve train on our Ice Injection test engines.
We now have 220 hrs spinning up to 6600 rpms on most every test run.
This is with 93 pump gas & methanol injected 565s 14 -71 high helix 14 honest lbs of boost using "Crane hydraulic lifters" and quite high spring pressure.
We hope to see 300hrs with out a tear down of any kind.
As we still leak down 9% cold.
We have had great luck with Crane lifters on these high rpm big power hydraulic applications!
BAD-HABIT
3
05-04-2002 09:15 AM
