No water flow  ..... >
No water flow .....
No water flow .....
Old 11-19-2008 | 06:30 PM
offthefront's Avatar
Default No water flow .....
Installed 2 new Drives one side is getting Little if any water flow. At first I figured it was the impellar but it looked ok but put a new one in anyway and still no flow ...Only thing I can figure is the hose in the Transom Assy or the barbed fitting inside .... I checked the Transom end of the hose when we hard the inside barb off and was ok ... Either we crimped the hose or maybe cracked the barb and its sucking air? ...This Drive has Duel water pickups ...m
offthefront is offline
Old 11-19-2008 | 07:49 PM
Thunderstruck's Avatar
Take the suction hose off the water pump and put some air pressure into it. See if pressure builds (hose in a bind, clogged water inlet) or find a leak by sound.
Long time cult member.
Thunderstruck is offline
Old 11-20-2008 | 03:30 AM
Good Idea .....
Old 11-20-2008 | 06:52 AM
Registered User
Dual water pick ups you should cover the the holes in the frount on the drive and did you check the o ring's when you installed the drives you may be sucking air .
clpbs is offline
Old 11-20-2008 | 02:48 PM
Found the problem .. The hose from the drive to the Transom is crimped .....We replaced the bellhousing too and I remember pulling the hose out of its little "niche" when I was installing the Bellows on the Transom end ...Hopefully thats all it is ...m
Old 11-21-2008 | 01:12 PM
thanks for the update. looks like you found the problem
Old 11-24-2008 | 06:54 PM
Pulled the drive today and sure enough the hose had spun with the insert ...back in the water and runs cool .....m
offthefront
73
01-20-2007 10:07 AM
GregP
0
06-18-2002 07:49 AM
HighPriority
5
04-05-2002 05:47 AM
High Maintenance
1
03-27-2002 10:54 AM
