Drive Temperature Sensor >
Old 05-11-2009 | 07:04 AM
  #141
Originally Posted by Rage
I am asking about the sensor that would include the stainless steel body that screws into the drives oil vent hole.
As of right now I can fix one that doesn't work, I do not have the swivel end that screws in to the drive to make any new ones.
waconda is offline
Old 05-22-2009 | 10:03 AM
  #142
Rage's Avatar
Originally Posted by Mr Gadgets
Rage,
I sent pics to this guy and he said he couldnt do it.. I asked for alternatives and he send some info on a double ened compression fitting.. SS. So I need to discuss it with him...
I will let you know..
Dick
Just checking. Anything new?
Rage is offline
Old 05-22-2009 | 10:09 AM
  #143
Rage's Avatar
Originally Posted by waconda
Yes I have the actual sensor to repair yours and I have some other parts. If you take out your sensor by cutting the wire harness inside of the hull a foot or so from the thru hull fitting and send everything from the thru hull to the drive to me I will repair it and put on a weather pac connector and send you the other half to install on the harness left in the boat. Cost $60.00
Could you provide a picture of the sensor that you have?
Rage is offline
Old 05-22-2009 | 11:09 AM
  #144
If any of you guys get these gauges working I'd really like to see some readings with and without a drive shower. I just question the need for a shower. If you look at the back of a boat running at speed there is water all over the place back there. That upper drive is NOT high and dry. At least not with a shorty and wet exhaust..........
thirdchildhood is offline
Old 05-27-2009 | 07:09 AM
  #145
I have the same sensor as fireboat has pictured on the previous page.
waconda is offline
Old 05-27-2009 | 07:21 AM
  #146
We took out the BT this last weekend and at cruising speed my drive temps were 140-150 and at over 5000 rpm they were at 200-210.
I have Bmax drives with XR bottoms so no drive shower do to the water jacketed housing.
I played with moving the center drive at different heights and you could see the temps change as the drive had more or less load put on it.
I must say it was nice to have them working again, I hate when a gauge doesn't work.
waconda is offline
Old 06-09-2009 | 09:44 PM
  #147
Update
Had the boat out this weekend and noticed that the temp was up on 2 of the drives about 30 degs when I was over 65 mph so I keep the speed down and when I got it home found the water hole that feeds the Bmax upper on those to drives were plugged with wood. So I'm pretty sure the senders saved my drives.
waconda is offline
Old 06-10-2009 | 07:21 AM
  #148
Elite Marine's Avatar
Well done John!!
Had a question on Promariner charger. See the other thread or email please.
Elite Marine is offline
Old 06-12-2009 | 06:06 AM
  #149
Rage's Avatar
Actually I was interested in a picture of the just the bare sensors that you have obtained that can be used to repair the sensor and housing assembly that is shown on the previous page
Rage is offline
Old 06-13-2009 | 11:18 AM
  #150
Rage's Avatar
Yes I have the actual sensor to repair yours .
Can you provide a picture of this "actual sensor" that you have? Would you be willing to sell one? Price?
Rage is offline
