Oil temp sender location >
Old 12-27-2008 | 09:06 PM
HotPursuit's Avatar
Originally Posted by paradigm shift
I have 2 senders one in the oil coming off the motor one in the oil coming off the cooler to the engine. I run one gauge and a simple switch under the hatch that I can change from one to the other. I usually monitor oil temp I am feeding the engine. I did this just to check how well my oil cooler was working a while back. Senders are pretty cheap.
I use a temperture gun, but 2 senders is a nice option..
HotPursuit is offline
Old 12-27-2008 | 09:08 PM
HotPursuit's Avatar
Originally Posted by daredevil
I knew i did it right. LOL
Old 12-28-2008 | 02:00 PM
paradigm shift's Avatar
Yea I have an IR gun and it is useful but the problem or the issue I had was checking under power. Once I slow readings change rather quickly.
paradigm shift is offline
Old 12-28-2008 | 03:29 PM
HotPursuit's Avatar
I should have posted my meter has 4 Temperture input leads,if not stick your friend under the engine hatch!!!
Old 12-29-2008 | 06:32 PM
In the pan, you want oil temp after it has cycled through the engine. A spike in temp will tell you if something is loosing lubrication (IE bearing failure). Wet sump system take it in the pan, dry sump take it in the tank.
cstraub is offline
Old 12-30-2008 | 03:25 PM
offthefront's Avatar
Problem is when most people ask it is an existing installation and it will be difficult to add a pan located sensor .....
http://www.pegasusautoracing.com/pro...p?Product=1227
offthefront is offline
DORaymond
5
06-07-2005 11:10 PM
CN24
2
01-16-2005 12:46 PM
Danny_Ocean
4
04-05-2004 10:47 PM
737jetmech
13
03-31-2004 07:56 AM
27 FOUNTAIN
26
02-11-2002 06:36 PM
