Oil temp sender location >
Old 12-23-2008 | 06:46 AM
Default Oil temp sender location
going to install a oil temp gauge and wondering where is the best place to put it the sender...I have 2 plugged 1/2 npt fittings on my remote oil filter mount, was thinking about there ?? thanks Rob
ezstriper is offline
Old 12-23-2008 | 06:53 AM
Do a search, this topic has been talked about in hundreds of threads.
I have always put mine in the filter pad for ease of location.
I am looking for a Fluctuation in temp regardless to where the sender is placed. If it reads higher than normal I would get concerned.
1BIGJIM is offline
Old 12-23-2008 | 06:54 AM
You want it in the engine block. I have mine right in the main galley hole right above the filter mount on the side of the engine you have to make sure you are not blocking the galley too. block even oil pan is a good . If you know the engine is not going to bypass the remote oil cooler and filter install it right in the remote filter housing.
Rockfish71 is offline
Old 12-23-2008 | 07:02 AM
obnoxus's Avatar
Charter Member #1171
Pan is the best place,,,,, you want to know what is going into the engine.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 12-23-2008 | 09:21 AM
Ok, I have been thinking about this....scary I know..but would it not be better to pick up oil temp away from the engine ? that way you are not getting a false reading from the temp the block is running vs just the oil ?? just a thought....Rob
Old 12-23-2008 | 09:29 AM
Absolutely,,,,,i always take it from the filter !!!!!
DareDevil is offline
Old 12-23-2008 | 05:41 PM
HotPursuit's Avatar
Remote Filter, this is the oil temp that is entering the block.The oil in the pan is before your cooler.
Just MY 2. If you stick a sensor in the side of a oil galley you will restict the oil flow.
HotPursuit is offline
Old 12-23-2008 | 09:39 PM
paradigm shift's Avatar
I have 2 senders one in the oil coming off the motor one in the oil coming off the cooler to the engine. I run one gauge and a simple switch under the hatch that I can change from one to the other. I usually monitor oil temp I am feeding the engine. I did this just to check how well my oil cooler was working a while back. Senders are pretty cheap.
paradigm shift is offline
Old 12-23-2008 | 09:50 PM
I knew i did it right. LOL
Old 12-24-2008 | 06:45 AM
seemed logical to me as you would get a "true oil temp" note heat from the block etc...
