Bennet tabs? >
Bennet tabs?
Bennet tabs?
Old 01-01-2009 | 06:09 PM
Default Bennet tabs?
My bennet trim tabs are stuck in place. I can hear the pump working down in the bilge when working the swithces, but the tab cylynders don't move. I can also extend the ram by hand, so I know they are not completely siezed.
Any one else run into this?
cstobe is offline
Old 01-01-2009 | 07:18 PM
Try opening the fluid bottle to relieve the air.. Worked for me.
Allirunner is offline
Old 01-01-2009 | 07:49 PM
if there bennets, they will warrenty pretty much anything
phragle is offline
Old 01-01-2009 | 07:51 PM
Make sure there is enough fluid in the bottle.
Also, I have seen the solenoids stick or quit all together. The pump will still run but the fluid won't move. Sometimes tapping on them will shock them loose. (plastic end of a screwdriver etc...)
And yes, Bennett is very helpful in getting you repaired or replaced...
26 Spyder is offline
FormulaOne
08-12-2008 08:11 PM
JS232
0
11-30-2005 03:49 PM
Scarab3DMC
1
05-16-2005 03:43 PM
migara422
02-29-2004 01:06 PM
bikinilover
Baja
3
02-03-2004 11:48 AM
