NEED Mashine shop help !!!!!!!!!! >
Old 01-11-2009 | 01:13 PM
Default NEED Mashine shop help !!!!!!!!!!
I need 8 studs ,grade 8 steel in half inch and 2-1/2 inches long with both sides corse thread (1inch each side) .
Cant find them any where ?!
DareDevil is offline
Old 01-11-2009 | 01:51 PM
If its not for head studs, How about all thread. Its pretty tough.
Noise Pollution is offline
What size threads? ARP should make them. If not I will check somewhere else for you.
598Boat is offline
Old 01-11-2009 | 02:12 PM
Steve_H
Threaded Rods and Studs
This product matches all of your selections.
Part Number: 90322A215 $9.56 Each
Material Type
Steel
Finish
Plain
Grade/Class
Grade 8
Type
Fully Threaded Rods and Studs
Steel Type
General Purpose Steel
Thread Direction
Right Hand Thread
Inch Thread Size
1/2"-13
Overall Length
36"
Rockwell Hardness
Minimum C33
Minimum Tensile Strength
150,000 psi
Thread Fit
Class 2A
Specifications Met
American Society for Testing and Materials (ASTM)
ASTM Specification
ASTM A354 BD
Notes
Length is measured from end to end.
© 2009 McMaster-Carr Supply Company. All rights reserved.
http://www.mcmaster.com/
Old 01-11-2009 | 02:50 PM
It needs to be both sides threadet and an1/2 ich in the center flat,,,getting bolted thru Aluminum at that spot !!!!!
Its for a Gimbal on a #5 ....and merc has them in stock for ,,,,,,,,,,,,,,,,,,unbelieveble $ 77 ,50 each !!!!!
I thought someone could help me for about 10 bucks each ?!
They are the short ones that mount the Gimbal to an Extension Box !!!!
THANKS FOR THE HELP !!!!!!
Old 01-11-2009 | 03:28 PM
I second talking to arp..somebody is making them...
ezstriper is offline
Old 01-11-2009 | 09:05 PM
CcanDo's Avatar
DareDevil - how many do you need? Also, are you sure you want steel, and not stainless? We probably have what you need depending on the quantity, but they will be coarse one end and fine the other - OEM Mercury. I will look tomorrow.
CcanDo is offline
Old 01-11-2009 | 09:33 PM
I need 8 of them,,,,,,but yes they are grade 8 steel .
Stainless will not take the abuse on a #5 at the gimbal.
If you got 8 locknuts in stainless for the finethread ,,that be cool also .
But i will not pay merc prices at 77 bucks each ,just for the stud. They are out of there mind. LOL
Thanks. My # 941 592 5815
Old 01-12-2009 | 07:22 AM
Pwrbt33's Avatar
http://services.vehicle-web-services...FF%20BOX%20KIT
Follow this link! This sight is showing them for $24.99. You need to scroll down to find the part #16-43449. Its showing the website as Dollar Marine.
Hopefully this helps!!
Pwrbt33 is offline
Old 01-12-2009 | 07:55 AM
Im in the machine shop business. You need a rolled thread thread not a turned thread. I can turn them from 4140 or 4150chrome moly. A cut thread isnt as strong as a rolled thread. I can only cut the threads. Theres a shop that rolls studs in town. Ill check to see if their still in business.|
Bobby
BDARCHER is offline
