Sea Water Pressure of 496HO
Thanks Monstaaa,
My 496 is no longer stock but the sea water system is and the Diacom data is showing 43 psi at 5800 rpm and mid 80's. Just trying to get a handle on if that is a good number or not since it seems high. I am looking for any additional cooling capacity to include plugging the above water water intakes of the Bravo X1 drive. However if alreay at 43 psi more pressure may not be a good thing. Already have a much bigger oil cooler as well but still need more cooling.
Hey Bill, next time you're at your boat turn the key on without starting your engine and check if diacom shows any water pressure. What I have experienced is after Whipple reprograms the PCM that they will show about 20 psi higher water pressure. It will have a reading even without the engine running. So your readings may not be correct. I just tested a stock 496 and was reading around 20 psi at 60 mph on the Smartcraft. Dustin has not been able to explain why that happens, but it has on every one he's done for me.
Bob
Bob
Bob
Bob
Wow, that is excellent information. I'll do as you suggest.
Thanks,
Bill
28Eliminator
11
06-22-2004 10:43 PM
