Oil leak-remote set up. >
Old 01-27-2009 | 07:27 AM
Default Oil leak-remote set up.
I've got a BBC witha remote oil filter. After having the engine rebuilt, I've had a leak where the remote fitting is (where the oil filter use to be). What normally goes bad-the fitting the O-ring or a gasket?? It's very hard to tell exactly where it is leaking due to it being in the bilge. Should I replace the whole fitting? What is the best way to solve this? New Fitting?? Thanks in advance!
Bob G
Fast Shafts is offline
Old 01-27-2009 | 09:11 AM
The center bolt/ fitting may be loose. I've forgot to tighten them before.
kennyo is offline
Old 01-27-2009 | 02:05 PM
is it a gen IV or V/VI the bolts on some of the gen IV need copper washers to seal them (2) and there is a large O-ring seal on the adapter also, gen V/VI also have a O-ring seal as well, and not the same as the filter...Rob
ezstriper is offline
Old 01-27-2009 | 09:44 PM
It's a Gen IV. Thanks for your responses!
Old 01-28-2009 | 04:50 AM
Mr Gadgets's Avatar
Charter Member #601
Any one have a source for those copper washers??
Mr Gadgets is offline
Old 01-28-2009 | 07:51 AM
I went to a auto parts store matched up brake hose/caliper washers, crusader list them..sure merc does as well....Rob
Old 01-28-2009 | 08:06 AM
obnoxus's Avatar
Charter Member #1171
I agree with kenyo,,,, clean it up then get down there and keep an eye on it idling if you can,,,, may just be a loose fitting, or the center adapter fitting that holds it to the block
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 02-06-2009 | 10:10 PM
mine leaked after my rebuild, it is probably the seal to the block, I bought 2 oil filters with the same size rubber gaskets (took them off the filters) and replaced them....fixed the leak
welfare racing is offline
Fast Shafts
0
01-27-2009 07:25 AM
Velocity Vector
0
04-03-2008 01:45 PM
docmanrich37
13
08-09-2005 06:49 AM
powerguy
5
08-04-2002 07:44 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
