mercruiser oil fittings??? >
Old 01-31-2009 | 11:23 AM
Default mercruiser oil fittings???
Does anyone know who make mercruiser oil hoses ? I'm tring to find the fitting to make up some hoses, they are 1/2 inverted flare fitting . The hydraulic shop has some fittings but they are to large . I need to find some smaller fitting similar to merc's hoses, I can have them made for 1/4 the cost .
alecsammy is offline
Old 01-31-2009 | 11:41 AM
Find an aeroquip dealer in your area. They have everything.
Griff is offline
Old 01-31-2009 | 01:23 PM
right... and convert to conventional 37 deg adapters so all your hose ends are now conventional
stevesxm is offline
Old 01-31-2009 | 06:46 PM
Default Merc Hose Headache
I have been down this track mate.
The aeroquip setup will cost the same as merc but check it out first.
I ended up buying tube , flare nuts and the crimp fittings to suit.
Bend and cut the tube(flare nut on first)
Modify crimp fitting to accept tube
Silver solder tube to crimp fitting
Take back to hydraulic shop to crimp hoses.
Worked out about half the cost $60. bucks Aussie each.
All stainless steel fittings , Braided hose.
Hope this helps
Cheers
bustedarse is offline
Old 02-06-2009 | 10:03 PM
I did 2 engines for 36.00
8 fittings, 4 push on blue hyd line
works great
Here is their website here in the detroit area, call them and they will know exactly what you are doing....its a popular set up
http://www.fluidsystemseng.com/parke...e-michigan.htm
586-790-8880
welfare racing is offline
Old 02-08-2009 | 12:33 PM
spazboz's Avatar
I believe the merc hoses on the 420 I'm working on were made by Gates.
spazboz is offline
Old 02-08-2009 | 08:35 PM
I went with aero-quip and -12 lines the merc stuff is too small
Sweet Nmocean is offline
Old 02-08-2009 | 10:39 PM
Just check the temp. rating of the hose you end up and use as some is not rated for the temps that engine oil can get to.
midwest272 is offline
alecsammy
2
01-14-2009 07:56 AM
brwn234
4
06-08-2008 07:06 PM
duunoit
9
05-17-2007 04:46 PM
offthefront
0
03-23-2007 09:44 AM
Monty
4
03-11-2004 02:48 PM
